Sometimes, in a lister, when I rename a file and hit "Enter", the focus is automatically put on the next file in the lister, and sometimes, it stays on the same file. I don't know why I have 2 different behaviors.
When I take pictures in voyages, I then rename those I keep. And I have a bunch of renaming presets which helps me gain a lot of time (with buttons shortcuts in toolbars in listers). So, if I apply preset A then preset B on the same picture, I want the focus to keep on the same file, until I choose to go to the next.
And I don't understand why sometimes it is like this, and sometimes not.
Yesterday night, my lister worked "correctly" (after renaming, the focus kept on the same file, so I could apply another preset, then another preset, to rename a part of the file).
This morning, after renaming, the focus is going always on the next file. So I have to go back a file after each click on a button (preset renaming shortcut).
I usually work in Thumbnails view, Viewer pane opened, and one lister.
I would appreciate to understand this behavior, and how to choose which one to force !
I have completely exited DOpus and restarted it.
I open a lister.
I go to the photos directory.
I display my toolbar (Right click in toolbars > Toolbars > click on my Photo Management toolbar).
I select a photo (currently in Details mode, dual directory)
I click on a button to rename the current file
==> The NEXT file in then focused automatically.
I am trying to recreate the behavior where the focus remains on the current file...
I will post if I succeed.
I have also tried to play with the option "Deselect files used in functions" and trying to put the @nodeselect before or after the RENAME command, in uppercase or lowercase, but it does not change the behavior.
When no file is selected, the buttons for renaming are grayed out. So, when I click on my "rename button", it becomes grey immediately. So I would say that the file is deselected.
The focus (light rectangle around the file) is on the next file, and if I press the space bar, then, the next file is selected, and the buttons are clickable again (but on the next file).
It sounds like the @nodeselect in the button is not working for some reason. The rename preset looks normal enough so I don't think it is that (at least not on its own).
Could you take a couple of screenshots of the main window/lister showing the files and selection before and after clicking the button? Maybe that will show a detail that I have not thought of.
Here are 2 screenshots : before and after clicking on the first file. The effect is to add a "comma + space" after the name of the current selected file (and before its extension).
We can see that the selection is lost, and that the focus is set to the second file.
