I'm experiencing some unwanted behavior with file collections.
Intro
- I have multiple disks mounted via NTFS volume mount points as sub-folders of C:\Mirrors.
- It goes like C:\Mirrors\DISK1, C:\Mirrors\DISK2...
- To clarify - each of these folders represents a separate partition on a different LOCAL hard disk.
- Also those partitions do not have drive letters as they became too many and were becoming a headache to manage.
- Each partition is only mounted in ONE of those folders and nowhere else.
Description
- Working with them directly from that folder is perfectly fine.
- Adding files from them to a collection is fine as well.
- Those files can be opened, sorted, viewed etc.
Problem
- Attempting to inline rename a file/folder from the collection view succeeds in changing the file's name but fails to update the name in the collection.
- Subsequent renames fail silently as the {old name} does not exist anymore.
I remember experiencing something similar before with the image viewer here:
Issues on renaming images from the image viewer so that could be connected in some way.
