Reorder Tabs by Drag and Drop
I use Maxthon and Firefox Web browsers. Both have the ability to drag and drop tabs so that I can reorder them in a way that makes sense to me.
I use DO in commander mode all the time with multiple tabs. It would be very helpful to be able to drag and drop to change the order.
Is that something that is possible to do or is it availabale now and I just don't know where to find it?
Thanks,
SoSweet
You can drag folder tabs in Opus, just remember to drag them by their icons, not their labels. (Dragging by the label is like dragging the folder itself, not the tab.)
AH HAH thats the problem. I was trying to drag by the labels. Thank you so very much for clearing that up for me! :smiley:
SoSweet
