That filter in the screenshot is fine, but I want to add to it.
I would like to also exclude files in folders with certain names - like excluding files in a folder named 'Thumbnails' or 'previews'.
I've been trying different things for over an hour with no success.
Is it possible to do? If yes, how?
Yes, add a Sub-Folder clause (at the top level, i.e. the same level as the the two existing Subclauses), and make that exclude things named 'Thumbnails' or 'previews', and it'll skip those folders (and all folders inside them) entirely.
No, there should also be a Sub-Folder option right below that in the list, which is the one you want for filtering out entire branches of the search hierarchy.
Perfect! Thank you.
I did see 'sub-folder' and looked it up in the online manual. Please consider changing 'subfolder' to sub-folder in the manual so it's easier to find.
