Resize dialog behaviour with grouped static text
As shown in the before and after screen grabs below, the attached simple resizeable dialog test button works well except that I can't figure out how to make the second static text control stay properly positioned in the G3 group when dragging the base of the dialog down.
Resize.dcf (4.81 KB)
Regards, AB
You've got the H resize option turned on for both of those static texts, which means they grow vertically as well as moving vertically.
Thanks Jon
Regards, AB
