Resize images
Why is it that if I try to resize an image to 1920 x 1080 with the following code:
Image WIDTH=1920 HEIGHT=1080 HERE
The two values are never changed correctly, sometimes the resulting width is 1920 and height close to 1080; and other times the resulting height is 1080 and width close to 1920.
A behavior similar to:
Image WIDTH=1920 PRESERVEASPECTRATIO HERE
Image HEIGHT=1080 PRESERVEASPECTRATIO HERE
The images probably have EXIF rotation flags set, so their dimensions are swapped. You can tell the image converter to rotate by the EXIF amount as part of the conversion/resize.
Thank you very much @Leo, I will try to correct that detail!
Hi @Leo, I have tested with several images without any type of EXIF information and I cannot change their sizes to the measurements that I specify, it is as if the "Maintain aspect ratio" option was specified, is there a way to force a new size without maintain aspect ratio?
Oh, sorry, I misread / misunderstood what was wrong.
So you want to distort the images? Your command looks right to me.
I think this is a bug. Will look in more detail next week.
True @Leo, when it comes to photographs it can cause distortions, but when it comes to uniform colors, patterns, etc., it will not cause distortions. Ok, take a look when you can, I really appreciate it!
