What is best way of restoring Dopus after a Reset?
Will my Licence still work ?
Your licence will work.
If you have a config backup, you can restore that via Settings > Backup & Restore.
If you don't have a config backup, but have the folders from the old Windows install, you can copy over the config folders from that. See the config backup FAQ for how to locate the config folders.
