Hi - I've searched this forum for my problem, but all the responses were for older versions of DOPUS, and they don't work. I need help to reset the sort order for date.
Many thanks
Many thanks
Do you sort by date created? In the column header there's that small arrow/triangle symbol. Clicking on it should reverse the sort order. Make sure to save the setting in the folder options to make it stick.
Can you give more detail on what you want to reset?
The date columns should sort newest to the top by default already.
