I work with a lot of multimedia files. I like having entire rows selected. However, I am having problems with performing a right click and paste command because there is no empty space available in certain folders' view to do so, mainly due to many different columns in the lister. Yes, I can do CTRL-V, or disable full row selections, even do right click and paste by selecting the working folder under the folder tree. But it is a bit inconvenient. I really need to figure out an easier way to just right click/paste inside of a folder I browse. What am I missing?
Thanks.
You can right-click on the status bar.
Ha! Never realized I could do that! Thanks for a quick response.
