Having a problem when I right-click on a folder that DO12 freezes in the range of 1-2 minutes while it's trying to build the context menu. Usually, the program eventually responds, returning control.
After DO12 builds the context menu, then subsequently there is no longer any wait period.
However, the initial freeze always happens every time after DO12 is launched anew—across multiple PCs. (So this appears not to be a PC-specific problem.)
Anyone else having this issue?
