Right-Click menu
I did a search for this and couldn't find anything to help...
The one thing from Windows Explorer that I miss is the option to enqueue mp3s into Winamp using the right click... and quite a few of the other options which that feature allows that dopus doesn't.
Is there a setting I could change to allow this on dopus?
Also, is there a 'converting from W.E.' faq file that I could read so I can see what else this prog allows me to do.
Cheers :slight_smile:
All your standard Windows context menus should be displayed in Opus, unless you have turned them off through Preferences. Check the state of the Miscellaneous -> Windows Integration -> Hide Windows items on file context menus flag in Prefs.
Yep, it's called "the manual" :slight_smile:
