Right click on Dopus tray icon "Open new lister" no longer works
Directory Opus 11.18 x64 build 5920, 3/17/2016.
What happens when you use it?
Do other methods of opening Opus work? e.g. Via the start menu, or desktop double-click.
Does a button for Opus appear on the taskbar, even if the window is not visible on the screen?
Did anything on the system change recently that might affect Opus, or where windows appear when they open? (Opus itself won't have changed recently if you're using version 11.18, so thinking about what has changed may point to the cause.)
Leo,
Did you receive my reply sent on Sep 20th, copy below?
Dick
-----Original Message-----
Sent: Wed, Sep 20, 2017 5:04 pm
Subject: Re: [Directory Opus Resource Centre] [Help & Support] Right click on Dopus tray icon "Open new lister" no longer works
Hi Leo,
When I right click on the DOpus taskbar icon and then left click on "open a new lister" nothing happens whatsoever. Incidentally, none of the other taskbar menu items work either (Preferences, Customize, Exit Directory Opus).
Opening Opus using all other methods work fine--double clicking on desktop icon, start menu.
I am using the portable version of DOpus. Hence there is no taskbar icon until I open the program via other routes (desktop icon or start menu).
I changed to a new USB drive and hence did a number of uninstalls and reinstalls of DOpus to get it to operate in the portable mode.
thanks,
Dick
