Hi,
I've opened a SFTP, and when I right click on the tab DO 9.1.1.8 crashes with the error window "An error occured reading folder: General error.".
After clicking OK the "right click window" appears (open, download, copy to clipboard, ..., properties). Be sure to click on the tab name!
This doesn't happen with a normal FTP connection.
Robert
Leo
2
I can't reproduce the problem so far.
What's printed into the FTP log (Tools -> Output Window) when you right-click?
It should trigger a read of the parent folder and result in a couple of lines like this:
SSH: Listing Directory
SSH: List complete 18 files.
(The count will be 2 greater than the number of displayed files in the parent due to the "." and ".." entries.)
Sorry, I may have forgotten to tell that I connect via a tunnel.
To avoid display problems with the screen shots and keep it readable I'll add multiple comments.
Here is the error when I right click on the tab:
After clicking the error message away:
Here is the FTP setting in DO:
And the last - the tunnel setting in MindTerm:
I've made a right click with the mouse over the tab over the word "localhost".
The problem only occurs with tunneling and connecting via localhost.
Normal SFTP works.
Please let me know if I should report an error to GP.
Thanks a lot,
Robert
Leo
8
If I set up the same thing then I can see an error message when I right-click the folder. I'll report that to GPSoftware for you.
You said there was a crash, though? How do I reproduce that? Or were you just calling the error message a crash?
(Crash = the program stops working to me, not just an error message that you can click and ignore.)
