RMB Preview Two Options (Images)
Hi,
When we have BMP & Tiff image files and use the RMBin DOpus to select image we get two Previews to choose from is this normal.
As for Jpgs,PNG,Pdf,Gif & PSd files we only get one to choose from.
Thanks in Advanced for your help.
Cheers, :smiley:
You can remove the Photoshop one if you don't want it. Go to Settings -> File Types, expand the bottom group and find the image formats you want to edit. In each of them, remove the preview item from their Context Menu tabs:
HI Leo,
Thank you for your help and fast reply. All sorted.
Couldn't upload BMP image in the forum what are the file types for uploading a images or where in the FQA's can we find it.
:sunglasses: avatar leo.
Cheers, :smiley:
Bmp's are far too big to allow posting into the forum. Most other formats will work fine. PNG or JPG are the best options.
Hi,
Thnx
Cheers,
