Running MMC has stopped working... elevation?
Hi guys
I have DirectoryOpus set up with a nice big toolbar with all my oft-used Active Directory Support tools set up on buttons with (for example) the following command programmed into them:
@admin:runas /u:<username> /savecred "mmc.exe DSA.msc"
Up until a couple of days ago, this worked absolutely fine: a command window would flash up followed by Active Directory Users and Computers. It stopped working for no reason that I can determine; no changes to policy etc. The Command Windows pops up, and vanishes, then it stops.
A little digging has revealed that I can run MMC.EXE elevated using right-click, "Run As Administrator" and also right-click "Run As A Different User" - it runs fine in both cases. However if I use the following command in a DirectoryOpus button, it no longer works where it did two days ago:
@admin:runas /u:<username> /savecred mmc.exe
Further to this, I cannot find a way to run this command interactively in DOpus so that I can see the output in the Command window without it vanishing - and no events are being logged in the Windows Event Log. Also, the button I have set up to do the following works just fine, and elevates properly:
@admin:runas /u:<username> /savecred cmd.exe
I have deleted and re-created my Windows User Profile (although I copied my DOpus AppData folders across to the new one) and this still hasn't helped.
I am running Windows 7 Enterprise 32 bit, and DOpus version 10.0.0.0.4137.x86
Can you help please?
Are you really running 10.0.0.0 or is that a typo? That version is a year and a half old so if you're running it, before trying anything else I would update to the current version (10.2.0.0).
LOL
The firewall here prevents automatic update checking so I always forget... this has started working again after the version update.
Thanks and sorry to have wasted your time.
