How do you save and reinstall buttons on a new DO update/install.
Started to use buttons and just updated my DO and found I had to recreate my buttons - how can this be prevented.
Thanks
Thanks
See the FAQs for info about backing up your config; however, if you just install new versions of Opus over the top of an existing install (without uninstalling first) then you don't need to do anything. It is only uninstalling that wipes the config.
(Major version updates -- e.g. Opus 9 to Opus 10 -- are sometimes an exception and might reset some things, but usually nothing that would take long to get back, and they'll ask you if you want to create a config backup when you install them anyway.)
Thank you for helping
