So I have a tab group open and then I add a folder to my current view. How can I 'easily' add the folder in view to the Tab Group?
You'd have to re-save the tab group, which can be done by right-clicking the tab bar or tabs, then Groups > Save.
It doesn't currently remember the name of the last group you loaded, but you can select it from the drop-down list which appears.
Alternatively, if you know you want to add a folder in advance, you can add it via Preferences / Folder Tabs / Tab Groups so it is included the next time you load the group.
Kind of obvious (now that I see it) and it works. Thank you.
