Saved Listers not working
I posted a query here some time ago regarding a save lister issue only to find that no lister layout I save are working (except ones created in a very old version of opus) I've attached a couple of image to demonstrate the problem...
This is the layout I saved as "Panaromic"
This what i get when I open "Panaromic"
Windows 7 Home Premium 64 with all updates, version 10.5.0.0 of Opus...
Suggestions?
Locked tabs will open at the folder they are locked at. Unlock the tab if you want it to show another folder when the window is opened. (Or re-lock the tab in the folder you want.)
