Script columns grouped in menu without spaces
Scripts can add columns. They can identify themselves like:
function OnInit(initData) {
	initData.name = "Script name";
	initData.version = "1.0";
which leads to expected name Script name shown in scripts window.
When script defines more than one column they get grouped into a submenu in "Columns" menu of a lister. Such group name appears to take its name from script name given groups belong to. For some reason this script name in columns menu is stripped from spaces so Script name becomes (harder to read) Scriptname. :face_with_raised_eyebrow:
That's by design, not a bug. Having spaces in column keywords makes it harder to use them in commands, which are the only places they're used.
Is the design a bit inconsistent?
These columns
look like this in the context menu
like this in a button
and are returned as
scp:Test String Script Name/Test String Col A
when tab.format.columns gets enumerated.
I'm not sure I understand.
If script defines only one column then it is displayed in menu with spaces, no problem. It's the script name being reduced that way, not the column names.
Column keywords shouldn't contain spaces, but that's up to you when writing the script. IMO it is an error to include a space in those names when writing the script, even if it technically works.
(There are separate fields for column display names that are actually shown to the user. Those can contain spaces, of course.)
Scripts don't have separate names and display names. Including spaces in their names is normal, and was already happening before script columns were introduced. The spaces in script names are removed automatically when generating fully-qualified keywords for script columns.
