Script Editor not responding to Scroll
The 2 finger trackpad scroll works in the command editor for a toolbar, lister but not for the script editor.
Which script editor do you mean exactly?
Is the trackpad one of the "high precision scrolling" ones or a normal one?
This editor, just the regular laptop trackpad does not scroll the text window (two finger scroll) which works in listers and other Opus UI elements).
Off topic, but relevant. There is a lot of wasted space in that particular list box, can we have it collapsible please.
I can't reproduce that, if you mean the main text area where the script is, that's mostly cropped out of your screenshot on the right.
Scrolls normally with both mouse wheel and touchpad.
Could be something in your touchpad configuration/drivers or a tool like autohotkey that might change what scrolling does depending on the window it's being sent to, maybe, but that's just a guess.
Yes, the main text area where the script is edited, it's not scrolling. All other Opus dialogs and Listers scroll with the 2 finger method including the preference window, customize window, file type window etc... No AHK being used.
Try plugging a mouse in and using the mousewheel. If that works but the touchpad doesn't, something is probably wrong with the touchpad drivers, since the scroll events they send should be identical to what a mousewheel sends.
It both don't work then there might be something else going on.
The mousewheel works
