Little glitch in script editor found. Very (very) minor. Just reporting.
How to reproduce :
- Create a script
- Add a dialog : It appears with its name with a red dot at the end of the line (+ a red dot at the end of the tab "Ressources")
- Save the dialog : red dots disappears (since it's not "unsaved" anymore)
- Rename the dialog (with F2 or contextual menu on dialog name) and really change name : red dots come back
- Save : red dot remains on the script name (but disappears in tab name).
You actually have to close that window and reopen it to have the red dot gone (meaning it was saved, and it was properly saved with the new name).
Note : after changing the name (when dot remains), if you revert back to initial name, red dot disappears on the dialog name line (but is back on ressources tab until you save again)
