Script not working after update
I have a menu shortcut to create empty text files. The code is
FileType NEW=.txt NEWNAME="norename:new"
After the last beta updates is not working.
Any ideas?
Thank you in advance!
J!
My guess is something unrelated to Opus or the update has messed with the .txt filetype and broken its new-file handler.
If you right-click and choose New > Text Document (or TXT Document) in Opus, does that work? What about in Explorer?
Ooopppssss You are right. I thought that the New > Text Document was unrelated to the script and I have removed it from the registry because I never use it since the shortcut!!
