When I change settings of this script, column is not refresh...
Option Explicit
Function OnInit(initData)
initData.name = "Colonne_AlbatorV"
initData.version = "1.0"
initData.copyright = "2023 Albator V (Michiels Thomas)"
initData.desc = "Nouvelles colonnes."
initData.default_enable = true
initData.min_version = "12.0"
initData.group = "Colonne"
initData.config.Separateur = "__"
Dim col1:Set col1 = initData.AddColumn()
col1.name = "Avant"
col1.method = "OnAvant"
col1.label = "Avant"
col1.justify = "left"
col1.autogroup = true
col1.autorefresh = true
col1.namerefresh = true
Dim col2:Set col2 = initData.AddColumn()
col2.name = "Apres"
col2.method = "OnApres"
col2.label = "Apres"
col2.justify = "left"
col2.autogroup = true
col2.autorefresh = true
col2.namerefresh = true
End Function
Function OnScriptConfigChange(configChangeData)
Script.InitColumns
Script.RefreshColumn("Avant")
Script.RefreshColumn("Apres")
End Function
Function OnAvant(scriptColData)
If Ubound(Split(scriptColData.item.name,script.config.Separateur)) = 1 Then scriptColData.value = Split(scriptColData.item.name,script.config.Separateur)(0)
End Function
Function OnApres(scriptColData)
If Ubound(Split(scriptColData.item.name,script.config.Separateur)) = 1 Then scriptColData.value = Split(scriptColData.item.name,script.config.Separateur)(1)
End Function
I have error here...
Script.InitColumns
End Function
Something need to be change ?
