Awesome, thank you!
This one also looks for "test" (possibly followed or preceded by any other characters like "dotest" or "testing") followed by exactly 10 digits:
Option Explicit
Dim countFiles, countFoundTags, countTags, file, files, reg, strReg, tag
Set files = clickData.func.sourcetab.selected_files
Set reg = new RegExp
reg.Pattern = "^(.*test\D*\d{10})$"
reg.IgnoreCase = True
For Each file in files
countFiles = countFiles +1
countTags = 0
countFoundTags = 0
DOpus.Output "File " & countFiles & ": " & file.name
For Each tag In file.metadata.tags
countTags = countTags + 1
If InStr(Lcase(tag),"test") <> 0 Then
countFoundTags = countFoundTags + 1
DOpus.Output tag
End If
If (reg.Test(tag)) Then
strReg = strReg & countTags & " and tag "
End If
Next
If Not strReg = "" Then
strReg = StrReverse(Replace(StrReverse(strReg)," gat dna ","",1,1))
DOpus.Output "File " & countFiles & " contains ""test and 10 digits"" in tag " & strReg &"."
End If
DOpus.Output "All Tags: " & countTags & ", Tags with searchstring: " & countFoundTags & vbCrLf & "--------"
strReg = ""
Next
End Function
I used a combination of all the input here and got something that seems to be working well (goo.gl/Nwc3jq).
Thanks!
BTW, here is the final version so far:
Option Explicit
Dim file, files, timeStamp, countFiles, countUpdate, countSkip, countReview, regex0, liveStatus
timeStamp = DOpus.Create.Date(now()).Format("D#yyyyMMddT#HHmmss")
countFiles = 0
countUpdate = 0
countSkip = 0
countReview = 0
Set regex0 = new RegExp
regex0.Pattern = "^(Name\()(.*)(\)\,\s)(Created\()(\d*)(\)\,\s)(Modified\()(\d*).*(\)\,\s)(Tagged\()(\d*)\)"
regex0.IgnoreCase = True
If (InStr(clickData.func.qualifiers, "shift") > 0) Then
liveStatus = " - SHIFT held during operation: All Changes are LIVE"
End If
DOpus.OutputString "Number; File Name; Old Tag; New Tag; File Type; Status; Reason"
Dim fileName, fileType, createdDate, modifiedDate, imgTaken, imgDigitized, tag, newTag, tagString, countAllTags, countSearchTags
fileName = file.name
fileType = file.metadata
createdDate = file.create.Format("D#yyyyMMddT#HHmmss")
modifiedDate = file.modify.Format("D#yyyyMMddT#HHmmss")
imgTaken = Empty
imgDigitized = Empty
tagString = Empty
newtag = Empty
countFiles = countFiles + 1
countAllTags = 0
countSearchTags = 0
If file.metadata <> "none" Then
countAllTags = countAllTags + 1
If tagString = Empty Then
tagString = tag
Else
tagString = tagString & " | " & tag
End If
If (regex0.Test(tag)) Then
countSearchTags = countSearchTags + 1
End If
'If InStr(LCase(tag),"name(") <> 0 Then
' countSearchTags = countSearchTags + 1
'End If
Next
End If
If (tagString = Empty) Then
If file.metadata = "image" Then
imgTaken = file.metadata.image.datetaken
If (Not IsEmpty(imgTaken)) Then
imgTaken = DOpus.Create.Date(imgTaken).Format("D#yyyyMMddT#HHmmss")
End If
imgDigitized = file.metadata.image.datedigitized
If (Not IsEmpty(imgDigitized)) Then
imgDigitized = DOpus.Create.Date(imgDigitized).Format("D#yyyyMMddT#HHmmss")
End If
newTag = "Name(" & fileName & "), Created(" & createdDate & "), Modified(" & modifiedDate & "), Taken(" & imgTaken & "), Digitized(" & imgDigitized & "), Tagged(" & timeStamp & ")"
'Image, NO Tags, Update with newTag
DOpus.OutputString countFiles & "; " & fileName & "; " & tagString & "; " & newTag & "; " & fileType & "; Update; 1"
countUpdate = countUpdate + 1
clickData.func.command.ClearFiles
clickData.func.command.AddFile file
clickData.func.command.RunCommand "SetAttr META ""tags: " & newTag & """"
End If
Else
newTag = "Name(" & fileName & "), Created(" & createdDate & "), Modified(" & modifiedDate & "), Tagged(" & timeStamp & ")"
'Other, NO Tags, Update with newTag
DOpus.OutputString countFiles & "; " & fileName & "; " & tagString & "; " & newTag & "; " & fileType & "; Update; 2"
End If
End If
Elseif (countAllTags = 1 AND countSearchTags = 1) Then
'Skip, Tag has already been updated with expected Tag string
DOpus.OutputString countFiles & "; " & fileName & "; " & tagString & "; " & newTag & "; " & fileType & "; Skip; 3"
countSkip = countSkip + 1
Else
'Review, Contains multiple Tags
DOpus.OutputString countFiles & "; " & fileName & "; " & tagString & "; " & newTag & "; " & fileType & "; Review; 4"
countReview = countReview + 1
End If
Next
DOpus.OutputString "-----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------"
DOpus.OutputString ""
DOpus.OutputString "Total Files: (" & countFiles & ") - Update: (" & countUpdate & "), Skip: (" & countSkip & "), Review: (" & countReview & ")" & liveStatus
End Function
I've updated the root post of this thread to include an example of reading and writing image metadata, which is probably more common than needing to work with the free-form "tags" field. Similar techniques work with MP3 metadata like Album Artist etc.
