If you look at this extract from a screengrab of one of my network locations you will see that the list breaks the screen, and I have to use the up/down arrows at the top and bottom of the list to navigate, see indicator arrow.
Does the DO11 beta fix it so that I can scroll up and down the list using a mouse? (I'm waiting for some of the dust settle before trying DO11 before throwing it at my PC.)
If not, is this a feature worth adding?
Internet Explorer certainly allows scroll navigation, albeit in its usual clunky way.
This grab comes from using the GO function to navigate the network, but it also appears in other circumstances.
I agree it's not ideal, although I don't think the breadcrumbs menus will ever be an idea method of navigating a large, nested folder structure. They're good for quickly jumping around simple structures but the folder tree and file display will always be better for things like this example, IMO. (But it'd certainly still be good to improve how the menus behave once they fill the screen, and it is somewhere on our long ideas list.)
