Second Click in Right Lister Pane doesn't trigger filename edit
Opus Pro 11.15.2 (Beta) x64 Build 5700, 2015-08-10 3:10:00 PM
Second Click in Right Lister Pane doesn't trigger filename edit.
The title pretty much says it all. F2 on selected file puts filename in edit mode, but a second click does not. Second click DOES trigger edit mode in left pane.
Allen
Directory Opus Pro 11.15.2 (Beta) Build 5700 x64
OS 10.0 (B:10240 P:2 T:1) SP 0.0
Which view mode is the right panel in? Details, Power, etc.
Sorry, forgot to add more details. I just tested all modes in the right panel, and second click never triggers edit: large icons, small icons, list, details, power (as expected second click just selects / deselects), thumbnails, and tiles.
Allen
Does it matter which folder is in the panel? e.g. Try the same folder as in the left panel.
It doesn't seem to matter what folder is open. I've tried multiple drives and also virtual folders (e.g., desktop).
Problem persists with or without folder trees displayed. Second click DOES activate name editing in both folder trees.
The one thing I have not done is to close this instance of DOpus, since I wanted to be able to do more testing.
When I do open a new lister, both panels behave correctly. So the condition is unique to this instance. At least it's consistent within this invocation of the app.
I'll keep it open if you'd like me to try anything else. If you prefer to chalk it up to general weirdness, let me know. F2 was working anyway, so it hasn't been a problem. But it is one of those things that make one wonder if there's something wrong somewhere down deep.
I do tend to keep some instances open all day, so there's no telling what gyrations they've been through to precipitate this issue.
Allen
Are we talking about left and right dual file displays, or the folder tree vs the file display?
Could you post a screenshot of where you're clicking so we can see set exactly what's happening?
If it's specific to an instance then what's probably happening is a previous inline rename (or possibly drag & drop to or from the window) has gotten stuck somehow, blocking another from starting.
That's unusual but can happen, especially if other tools are getting involved. If it happens again, try to think of any recent actions that might be unusual and might help reproduce or understand what is happening. You can run them by us here if you want.
Yes, left and right dual file displays. See screencap.
I'll let you know if it happens again.
Allen
