Selected lister background color
Is it possible to modify the bg color of the selected lister window ?
Basically what I want is the bg color of the window to change to another color when this window is selected so I know which one is active
Mind you, I have kingofdaclick theme.
Ty
Preferences / Display / Colors and Fonts / File display background has separate settings for source and destination background.
Thank you, I had already found it and also changed the file display border source.
What I am trying to do now is to change the color of the name tab in each lister can you please tell me how to do it ?
no need to, I found it :slight_smile:
Hi, I see you found the answer to your own question. I am looking to do the same but havent been able to figure it out, could you please share how you did it. Thank you
If you right-click the tab, there is a Set Tab Color option. You can also assign tab colors to specific folders, or control them via scripts. The best method will depend on what you want to use the colors for.
For the actual background of the tabs, Preferences / Display / Colors and Fonts allows you to set that.
hi, sorry for the noob question. but i have a split view, what i want to do is gray out one side while i am working on the other side, then when i go to the other side turn it white again and gray out the previous side. is this possible?
Yes, set the top two colors under Preferences / Display / Colors and Fonts / File display background.
Awesome. Thank you!
