Send To and Shift to Move
My apologies if this has been covered before....
I use the right click context menu option Send To to copy files or to move them if I use the Shift key at the same time as clicking the destination Send To location.
The move feature works for files in any folder in Vista Windows Explorer but in Opus 9.0.0.4 it only works on the Desktop. Using it in any other folder only copies the file whilst pressing Shift.
It would be handy to have this work properly in Opus.
Thanks....Max
Problem solved by setting up a custom button on the toolbar to use the copy move to functions.
