Go into "customize" mode & drag it there.
Oh, it's simly! Sorry! Thanks!
drag not accessible! :\
I don't think you can re-order the Send To menu but you can create your own menus & sub-menus (with any order you want) which do the same thing, if you want.
Ok!
SendTo is not DOpus internal menu, but in my winxp drug'n'drop switched to work in menu...
OK! I try manage the DOpus menu to myself! Thanks!
