I am running Opus 9.5.0.0 and Windows 7 Home Premium. When in Opus the "SendTo" entry never appears in the context menu when right clicking on files. However, it does appear on the context menus when invoked under Windows Explorer.
I have tried both right click and shift-right click. I do not have the option checked to "hide windows options on file context menus".
Update: Jon says the fix was for items not showing up in the menu, not for the menu not showing up at all, so the new version probably won't solve the problem. (Might be worth a try anyway, though.)
I don't think anyone else has reported the same problem, FWIW. Not sure what could cause it.
Ooops, I spoke to soon. The "Send To" context menu selection does not appear when a shortcut (.lnk) is selected. It does appear for other types of files.
