SendTo with Shift key: Move?
In Windows Vista Explorer, when using the 'Send To' feature on the context menu of a file, while holding the SHIFT key pressed, MOVES the file to the SendTo-destination (instead of copying the file when no Shift key is pressed).
However this does not work in DirctoryOpus 9.0.0.7.
So how can I achieve this in DOopus?
In Vista Explorer the Send To menu always copies files here, whether or not I hold down shift (or ctrl).
At least, that's the case with the Documents destination. I didn't try any others.
