Set COLUMNS=35mmfocallength display a column "companyname"
But adding the column from Lister Column Hedaer » Pictures » Focal lenght (35mm) - work correctly.
Regards, Mani
Regards, Mani
Thanks! We'll fix this in the next version.
As a workaround you can use the numeric value 77 in place of the column name (e.g. Set COLUMNSADD=77
Thanks, Boss!
