Set Default View Mode for Certain Folders
I have some folders that have a lot of PDFs or lots of images.
I have my default view set to "details" normally, and need to switch to thumbnails quite often.
Is there a way to simply default certain "view" modes depending on what folder I'm in?
Perhaps having some form of directoryOpus .dcf? file type sitting inside the folder
Preferences > Folders > Folders Format and add some "Path Formats" there (you can configure them as you like)
is there a way to specify all of its' subfolders to behave the same way?
I don't see that option here
Look on the options tab.
