SetAttr META coverart:-3
SetAttr META coverart:-front
Unless I am misreading something, these two commands should do the same thing, but they don't. The keyword works, where the value does not.
Also, is there a way to tell which 'place' or value, an embedded cover art is at, if hovering over it in the metadata pane shows nothing. Put another way, I have mp3s with two embedded images. If (in the metadata pane) I hover over the first, the tooltip comes up and says "Front cover" whereas if I hover over the second, it is literally blank.
This is how I found this bug (if it is one) because I thought I'd just start at 1 and keep going until I found which 'value' this second image was at, but I never got past 3, because 3 won't delete the front cover, where the keyword 'front' will.
Bug, or my misunderstanding something?
ta
