In thumbnail mode, when dragging 1 to 4 files to a new folder it shows images of the thumbnails during the move; >=5 files it just says number of files. I'd prefer the latter as it doesn't obscure the target as much, but cannot find a setting location in the prog or forums. (I believe there's a similar setting in Windows "Performance options" about "Show window contents while dragging", which I've turned off already). TY.
Settings / Preferences / Display / Options / Drag image opacity = 0
TY! A quite different approach from windows's setting.
