Shared Background Image Problem
Hello,
I just upgraded from 6 to 8. Nice Job. I use a dual lister with a background shared among all elements. After the upgrade, the name column in the file display does not pick up the image. It only displays a white background. Am I doing something wrong, or is this something that will have to be fixed in an update?
Thanks,
Martin Gargotto :slight_smile:
This is Opus highlighting the current sort column for you. Click on a different column header to resort and you'll see the "white background" jump to that column.
If you turn on the Blend file background colors with background option in Preferences / Display / Options then this color will be alpha-blended with your background image instead of replacing it completely.
Or, you can disable the sort column color altogether from Preferences / Display / Field Colors
