Shared dimensions in script dialog
I was trying to create a dialog where the two list views share the same width, and the edit control shares the same height as the list view on the right. But this is what it currently looks like when resizing the window.
Any suggestions on how to make it work? Or is this a current limitation?
dlgtest.opusscriptinstall (2.3 KB)
I think it's because the "shared width" resizing mode divides the extra space by the number of controls. So for shared width, it assumes they will be next to each other.
Not sure if there is a workaround for that at the moment. What you really want is to be able to anchor one control's edges to another's, I guess.
It requires a little bit of effort, but is possible (i think).
I don't think that your example is using any control with shared width/height enabled :upside_down_face:
But they are next to each other. The issue seems that expect just one control per side. If I remove a control from the right side then it will work.
it assumes they are all next to each other horizontally, not on top of each other vertically.
