Shift + Delete icon no longer forces delete
This had been working until I removed the delete icon from the toolbar then added it back. Now it will only prompt to send the selected item(s) to recycle bin whether I hold down the shift key or not.
The del key works as expected and sends to recycle bin and the shift + del key forces a delete.
The only 2 items checked in 'File Operations | Deleting Files" are items 1 and 4.
Any ideas on how I can get dopus to revert to the previous shift + delete icon behavior of forcing a delete?
Thanks
The button's command should be:
Delete SHIFT
Thank you Leo, that restored the button to it's previous behavior.
Next time I'll be more careful about what I remove. :wink:
As Steje would say, Settings -> Backup & Restore is your friend. That way if you do make a mistake you can dig out your previous settings.
(Or do what I do and have incremental backups of the C-drive done every night. Opus's config is stored in files so you can easily grab stuff from a backup when needed. Also handy for when Firefox goes crazy once a year. :slight_smile:)
