Shift Delete
When I shift+delete then Dopus often shifts into the background. Bug? I use 8.1.0.5.
hmm.. works fine for me
I didn't say the deleting doesn't work.
It always deletes the file(s) but sometimes it just pops up the windows that are behind dopus as well, i.e. shifts dopus into the background. How about trying it out 100 times as a test.
This has occured ever since 8.0.0.0
I can confirm I get this sometimes as well.
Is there some bug tracker or will the developers read this here?
Hello,
works fine for me..
Please tell me your Version ANSI, UNICODE?
Stefan
odino... the GPSoft guys do indeed check in here at the forums but the 'official' place to submit a bug report or request for tech support is on the GPSoft support webpage.
