Shift Key and SetAttr Meta Behaviour
The following demo button code and screen grabs illustrate the issue. I added the test button to a vanilla configuration.
As soon as I press the Shift key (just Shift on its own) the button is greyed out and becomes inaccessible until I switch to another tab or the other side of a dual lister.
Regards, AB
Reproduced... FWIW - it only happens if you do NOT have an item selected in the lister (file or folder, doesn't matter).
Also, hitting (Refresh) also lights the button back up...
Thanks, confirmed.
