Shortcut for age
I've been using age script by chuck,what's the command to ascend files and descend by age
regards
In general:
Set COLUMNADD="<column name>"
Set SORTBY="<column name>"
You don't need the first line if the column is already added and you just want to sort by it.
The button editor can find the column names for you. Click the Advanced button if it is in single-line mode, then type Set and then click the Arguments menu and select SORTBY in there to get a list of columns.
what's the command for descending files
See the SORTREVERSE argument: https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Set.htm
