Is there a way to define shortcut keys to change the way files are sorted ?
For instance, in another application, I'm using the numpad keys, 1 to 4, to change the column sorting. E.g. Pressing "1" sorts by filename, pressing it again reverses the sort order. "2" will sort by file size, "3" by file type etc.
