Shortcut (.lnk), display real path
Hello,
is there a way to show the real to a file, if I click only on the shortcut (.lnk)?
I know I can set a row for showing this, but I would like to have this preferable in the pathbar seen or the status bar.
Any suggestions?
It should be in the infotip when you hover the mouse over a shortcut (or hold the Ctrl key when it has the focus, if using the keyboard).
That and the Target or Description columns (which will both show shortcut targets all the time) are the options.
