Shortcut to a lister
i created a lister's layout that contains split view and show me 2 folders i work with constantly.
i can only choose thos lister from Setting->lister layout-> my layout's name.
is there a way to create desktop shortcut to it? or at least an ability to add it as a custom button to one of the toolbars?
Thank you much,
David
To create a desktop shortcut to the layout, just go to Preferences / Layouts and Styles / Layouts and drag the layout to your desktop.
now, when I click dcf file nothing happen (extension not know by system).
how to run command from file? which is the command line?
[quote="AlbatorV"]now, when I click dcf file nothing happen (extension not know by system).
how to run command from file? which is the command line?[/quote]
Something has broken/deleted your .DCF filetype.
To repair it, either re-install Opus over the top of itself or run this from an administrator command prompt:
regsvr32 "C:\Program Files\GPSoftware\Directory Opus\dopuslib.dll"
ok but I have no admin rights here :frowning:
If you can't repair the .DCF filetype then you could make shortcuts or whatever which run a similar command via DOpusRT.exe.
e.g. "C:...\DOpusRT.exe" /cmd Prefs LAYOUT="My Layout"
