Add kb shortcuts to move file to top,bottom,middle and to move by one level up/down(dragging with mouse is painful if there are many files and also time taking)
You can use the Home/End/Page Up/Page Down keys for this (with Alt+Shift held down).
can i change alt+shift to single hotkey and where to edit it ?
No.
add one level up/down and change hkey for that
I don't know what that means sorry.
i.e to move file by 1 position up/down for e.g if there are 3 files like this --
a
b
c
move c to b's position.
Alt+Shift+Cursor Up/Down. This is all in the manual.
change it to single key
No.
will u change after 2,3 months I'll remind u
Nope!
