Is there a simple way (one or no clicks) to achieve consistent specific lister placement and size? Remember the "good ol' days" of Windows XP and how the built-in file manager would open folder windows where you last left them in the size you left them? I long for that. Can something similar be had in Opus? If not, I request is as an Opus behavioral feature. Using the product is good, tinkering with the product is bad.
I guess what you want is to enable the option "Update default Lister automatically when closing a Lister" which can be found in: Preferences / Launching Opus / Default Lister
No, I want, e.g., "D:\Data" to always show up in the same place in the same size as it was the last time it was closed when using a shortcut to reopen it.
