Simple Filter
When in "Commander" or "Single" view mode, is there a simple way to filter the files which are displayed, like WinFile used to?
I could be wrong but I don't think Dopus makes use of 'Display' filters like some of the other file managers do... Which is funny because it was a feature I never found any use for until recently :slight_smile:. Adding yet another use for 'filters' in Dopus such as this would surely require a more accessible and centralized filter manager utility or tab in preferences.
You mean filters like these?
Customize, Commands, View:
Hide Files Field
Hide Folders Field
Show Files Field
Show Folders Field
I stick the Show FIles Field on my main toolbar (with ctrl-q hotkey for quick typing into it) and put the rest on the toolbar you can see toggled on in the screenshot. I toggle that with ctrl-F and/or a menu item.
'doh'
nice catch!
Hi Nudel,
Thankyou very much !
I often use the 'Show Files' filter, but you really got it.
Thanks !
BTW, you really do need a copy of Double Fantasy ( John and Yoko ) in case you might not have it yet.
It was released posthumously as you probably know.
My view of London is from the Abbey Road web cam.
:opusicon: porcupine
Thanks!
