Simple find - not character '~' not working as expected
Any word is off, wildcards is on.
~filenameThatIsPresent
~(filenameThatIsPresent)
(~filenameThatIsPresent)
none of these work as expected, though putting Any word on and using - instead of ~ does work.
See
Filter Bar (~ Not) is not working - PrivateBeta - Directory Opus Resource Centre (dopus.com)
The 2nd should work to exclude a file whose full name (including extension) is filenameThatIsPresent.
~(*filenameThatIsPresent*) may be what you’re really looking for.
My bad, was searching for a word in a filename instead of a word as a filename (so used to have Any word checked AND it's been updated). Also must include extension. (Maybe a need for an include extension checkbox ?)
Your reply works perfectly, many thanks.
