Single background color selection
Is there a way to select a single background color that is applied to ALL DOpus windows?
I need to reduce eye strain all default white windows cause. I read the manual, searched the forum and have experimented with Display option settings, found Viewer pane background in Other Colors, but can not locate an option that applies the color to ALL DOpus windows.
thanks
hime
In Preferences/Display - Color and Fonts, you can change many background like file and folder tree. :slight_smile:
