Skinning Opus with WindowBlinds not (fully) possible?
Here are two images with opus using the same Visual Style / Theme.
First one uses default ".msstyles" Visual Style and the second one WindowBlinds to skin it. As you can see, WindowBlinds doesn't skin everything, just the titlebar and borders. I tried several themes to be sure it's not a faulty theme. All give me the same result.
Question: Is there a way to achieve the same result as Screenshot #1 with WindowBlinds?
Opus version used: 9.1.0.3
WindowBlinds version used: 6.02
Did you check Settings ->Preferences -> Miscellaneous -> Options -> WindowBlinds compatibility mode?
of course i did. this only enables titlebar skinning
what is the theme's name please ?
theme name: Crystal Systema
It would be, by the way, very handy if Windowblinds compatibility could be
adjusted for the frames (the outer thing) & the changed designs inside the lister. Sometimes i like the outer theme, but the inside will show too dark tabs, or alle the lines or the font look blurred.
If that could be turned on independently, that would be cool. But most likely it´s not possible, because of how Windows handles this (rather than Opus).
